Never mind, I'm blind, managed to find it.
Solved! Go to Solution.
Hi @Caper,
To stop the auto-renewal of your BritBox account, log in to My BT.
You can find out more here - Managing your BritBox account
Thanks,
Paddy
Login to my BT select your products scroll down the page the option to cancel should be next to the Xbox trial.
Hi,
I've just gone into my account to cancel the Britbox subscription and I cannot locate the option anywhere on my account. It's not next to the Xbox subscription as someone suggested. Please can you help?
