JT42
Message 1 of 23
How to connect YouView Box when hub in another room
We just got BT TV and broadband and wishing we'd stayed with Sky. our main phone socket is in the hall near the front door, and our TV is in the living room. There is a phone socket near the TV, but the home hub won't work in it.
I've read other posts mentioning extenders and adaptors, but find it all a bit confusing. Can someone please explain in simple terms what we need to do to get our YouView box connected to broadband? And if we need to buy any extra equipment, links would be most helpful.
An extra long ethernet cable isn't an option.
We have regular broadband, not infinity as cabinet full.
Only subscription channels we have are kids TV package.
Thanks in advance!
22 REPLIES 22
Zombie
Expert
Message 2 of 23
Re: How to connect YouView Box when hub in another room
Hi @JT42 sounds very much like my set up. Main socket in hallway ect. I use these and I honestly can't fault them, for me they work perfectly, I can stream the ultra hd channel and record another without problems.
https://www.shop.bt.com/products/bt-mini-connector-kit-087372-CMS2.html?q=Mini
Very simple set up, plug in near your hub if you have no spare socket the mini connectors have a plug on them so you can plug the hub into the connector then plug the connector into the wall socket, you get 2 ethernet cables as well, link one cable from the connector to the hub. Take the other mini connector to the tv area plug in and link a ethernet cable from the mini connector to the back on the bt tv box.
NeilO
Moderator
Moderator
Message 3 of 23
@JT42 the mini connectors are a good solution to connect your Hub to the Youview box. They're offered at a discounted rate of £20 when placing your order for BT TV and you can get them for this price as an existing BT TV customer too if you get in touch with the BT TV team on this link.
JT42
Message 4 of 23
Thank you!
JT42
Message 5 of 23
Thanks so much, just ordered them via chat 🙂
NeilO
Moderator
Moderator
Message 6 of 23
@JT42 No problem at all.
sea2dog
Message 7 of 23
Will I require these mini connectors too as our optical box is in a cupboard in the middle of the house and we have an ultrafast smart hub and a youview+ box and I'm concerned how the two will be connected given that the smart hub will be in a cupboard with the ONT and the TV box in the lounge?
Keith_Beddoe
Message 8 of 23
You will need a couple of them, they are available at a discounted rate, as mentioned by @NeilO
sea2dog
Message 9 of 23
Will I need any special cables etc to work with these mini connectors?
sea2dog
Message 10 of 23
Do these mini connectors work by WiFi or do they have cable connected to them?
