Message 1 of 6
How to connect cctv with bt hub
Can anyone help me set up my h.264 cctv cameras to bt hub thanks
5 REPLIES 5
Message 2 of 6
Re: How to connect cctv with bt hub
this might help  it is a site by @Keith_Beddoe   http://forumhelp.dyndns.info/hardware/hardware_menu.html
Message 3 of 6
Thanks but it doesnt support my system
Message 4 of 6
The principles will be the same. Give your camera a static IP address on the camera itself in the range 192.168.1.1 - 192.168.1.63 and forward the relevant ports to it. Sign up for a dynamic DNS service to allow access from the internet.
Message 5 of 6
Cctv
Has anyone got h.264 cctv system connected to bt hub ?
Message 6 of 6
Re: Cctv
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
