Newbie
Message 1 of 5
How to find out when 80/20 will be available to me ?
Hi folks
I was wondering if there is any way of finding out when my cabinet will be going to the 80/20 circuit ?
Just a quick background on my BB, I've recently ( 27th April ) had infinity installed and the engineer from openreach told me that my circuit is still on the 40/10 system, and he wasn't sure when the circuit would be upgraded.
I'm more than happy with my new speeds of 22mb and 3 mb up, but would be nice to get even faster speeds for the same price.Smiley Happy
Many thanks in advance.
4 REPLIES 4
Guru
Message 2 of 5
Re: How to find out when 80/20 will be available to me ?
What does it say when you put our number into the Infinity checkerhttp://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=29017&s_cid=con_FURL_infinit...
The new 80MB is already available to everyone, but considering your download speeds at the moment, i would stay put, since the new 80Mb uses higher frequencies, over a longer distance of copper wire would cause DLM a software on your line to work hard, which may cause decreased speeds for stabilisation.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Newbie
Message 3 of 5
The speed checker, says that I should receive 15.7mb , the same speed as it did when I first ordered infinity.
I take it that with my speeds being near the lower end of the Numb range, the 80/20 product wouldn't really benefit me, but would prob make the speeds slower? According the the openreach engineer we are about half a mile away from our cabinet.
Like I said before I'm more than happy with the new speeds, we was only getting 2.5mb previously from sky so its all happy days Smiley Very Happy
Guru
Message 4 of 5
Yea i would definitely stay put, since your receiving more than predicted which is great! half a mile away is quite far!
Message 5 of 5
Agree with Aaron, you'll not see an improvement by moving to the 80/20 service as it's effectively just an increase in the maximum rate you can connect at. As you're not hitting 40 you obviously can't go above that.
