Community Manager - Retired
Message 1 of 1
How to flag a post to a moderator
If you spot a post that violates the BT Community Terms of Service or User Guidelines you can flag it to a moderator.  You can also use this feature if you want to highlight a post or thread that is located in the wrong board and needs to be moved.
To do this, click on “Options” on the top right hand side of the post, and then select 'Report Inappropriate Content'.
Retired BTCare Community Manager - StephanieG and SeanD are your new Community Managers
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
