Hi all,
I have two calls for help.
I cannot get IPv6 working. My HH6 router tells me that I have an ipv6 address but test-ipv6.com says I have no access to the ipv6 internet.
A [heavily redacted] set of pictures tells the story of a thousand words, so here goes.
After choosing the reset option in the HH6, here is the ipv6 status page
And the next tab: The ipv6 Configuration page, which is at default settings:
Next, here's what the PC Wi-Fi adapter has:
Wireless LAN adapter WiFi: Connection-specific DNS Suffix . : lan IPv6 Address. . . . . . . . . . . : 2a00:xxxx:xxxx:xx01::192 IPv6 Address. . . . . . . . . . . : 2a00:xxxx:xxxx:xx01:bc9c:b1f:802f:472 Temporary IPv6 Address. . . . . . : 2a00:xxxx:xxxx:xx01:d13c:c679:1055:1416 Link-local IPv6 Address . . . . . : fe80::xxxx:xxx:xxxx:172%3 IPv4 Address. . . . . . . . . . . : 192.168.x.x Subnet Mask . . . . . . . . . . . : 255.255.x.x Default Gateway . . . . . . . . . : fe80::xxx:xx:xxxx:xxxf%3 192.168.x.x
And finally a report from test-ipv6.com
Request 2 adds some complexity: Behind the HH6 I have an old ADSL router running OpenWRT, which is NATted for ipv4 (and working well). The main reason I have this is because my internal network configuration is held here and it's the path of least resisance to keeping my internal network as-is.
From reading up on BT's IPv6 offering, we residential customers each get a dynamic delegated /56 prefix. That means I should be able to use OpenWRT to offer one of the subnet blocks, right?
The OpenWRT box has two vlans/interfaces, one for the Internet (a wired connection to HH6) and the other for the lan. So does anyone know the correct way to configure it is?
Thanks in advance,
Steven
Solved! Go to Solution.
Hi Smf22, thanks for the quick reply.
For Request 1:
I checked that the prefix on the hub was the same as on the client, and it was. Then I used the traditional fix for broken IT gear and found that the reboot of the router and of the client PC sorted the issue. So that's Request 1 sorted.
For Request 2:
If I understand IPv6 correctly - which is a tenuous consideration since I only have enough knowledge to be dangerous - it seems a waste of a /56 if only one of the 256 subnets will ever be used. I speculate that they are reserving the others for future use.
If I understand your last post correctly: I think you are saying that there is no prefix delegation from the BT hub because it's dhcp6 server is - ahem - crippled, therefore I ought to buy a new VDSL Router which features a dhcp6 server that DOES offer prefix delegation? If so it looks like I'll need to do a fair amount of homework!
In the meantime, is it possible to pick an arbritrary subnet out of the allocated /56 and give the lan port a static address, then configure ipv6 routing to make it work? I know that the prefix is dynamic but a cunning script on OpenWRT would be able get around that.
Yes, it's Infinity. I recently upgraded from ADSL and the increase in speed is phenomenal! 🙂
Thanks.
I have no issues at all with IPv6 on my smarthub as can be seen from the screenshot
Thanks @smf22 I think you're right: A swanky new router is in my near future 😄
@smf22 wrote:
Although if I were being pedantic, you wouldn't get 100% on some other IPv6 test sites as BT does not currently support IPv6 on their DNS servers.
Regards
Can you give an example of one of these sites? As all the sites I've tried have passed 100%
@Checked2013: Perhaps somethings changed for the better with the BT DNS servers. It always used to be that the last test at http://test-ipv6.com/ would fail when using BT DNS servers.
I assume your clients are using DHCP from the Hub and so using the name servers at 81.139.56.100 and 81.139.57.100?
I haven't used the Hub 6 or BT DNS servers for many months now so wouldn't have noticed any change. Thanks for letting me know.
Regards
