Message 1 of 4
How to split wifi channels on Smarthub2?
According to the My BT app, I should be able to split my 2.4 and 5 GHz channels to give separate SSIDs. I have selected a fixed channel for each and so have deselected Smart, but they remain as a single SSID. I am using a single disc, does that remove the splitting option?
3 REPLIES 3
Message 2 of 4
Re: How to split wifi channels on Smarthub2?
You can't split the SSIDs on the SH2, no idea why the app thinks you can.
Message 3 of 4
Thanks for the reply, just another example of joined up BT services.
Subsidiary question, what decides which band devices connect to?
Message 4 of 4
The device decides.
