dw79
Message 11 of 29
Re: How to stop Auto Forwarding email on BT Yahoo
Thank you
dw79
Message 12 of 29
After raising the issue with the helpdesk, I received a phonecall to say it was fixed...and it is! Don't know how they did it but it was obviously something technical!
HampshireLady
Message 13 of 29
I am having the opposite issue but the same results. I am fed up with BT's rubbish new interface plus the fact that my email has been hacked so I have set up a new email account that I would like to have my BT emails forwarded to. Like the dw79 the "Access your BT Yahoo Mail elsewhere" Forward option is greyed out.
I just spent the best part of an hour on "Chat" with a BT help person who has no idea how to solve this problem.
I note that this has been solved but would like to know how.
licquorice
Message 14 of 29
If you go to the cogwheel in the top right hand corner, select Settings > Basic in the viewing mail tab > save.  Then select Options in the drop down box and select go.  Then go to Mail Options > Pop and Forwarding. There will be the option to forward your mails.
MARKBAILEY
Message 15 of 29
Hi,
I'm also having trouble with this, it seems to switch over to BT  Mail has greyed out the settings, any one found a solution?
Thanks,
Jac
Andy_N
Distinguished Guru
Message 16 of 29
@MARKBAILEY wrote:
Hi,
Thanks,
Jac
Hi. Welcome to the forums.
Are you with BTMail or BTYahoo ? You can checked here :-
http://diagnostics.bt.com/login/?workflow=EmailChecker
POP & Forwarding (normally available via Basic setting) has been temporarily suspended by Yahoo! at present, but that wouldn't affect BTMail.
MARKBAILEY
Message 17 of 29
Hi Andy, thanks for your quick reply.
"You are currently on the BT Yahoo Mail service"
All mail is still being forwarded, still can't find a way to turn it off... I emailed a mod but no response as of yet so not sure if it's still the correct process to do so (as per a previous reply).
Thanks again,
Jac
Andy_N
Distinguished Guru
Message 18 of 29
Thanks again,
Jac
As I mentioned, POP & Forwarding has been temporarily suspended by Yahoo! - so no-one can help I'm afraid.
MARKBAILEY
Message 19 of 29
Ahh I get you... by any chance do you know how long it's been disabled for?
Andy_N
Distinguished Guru
Message 20 of 29
Not really sure, but it must be around a week or so now. I had it confirmed on 16 September.
