Message 1 of 21
How to use HH4 as a Slave hub?
Does anyone know how to use the new hub as a slave to the hh3?
Right now I am using a HH3 as a slave to HH3. Has anyone been able to successfully pair these two routers?
Thank you.
I am going to follow this guide to use my new HH4 as a repeater to me HH3:
http://forumhelp.dyndns.info/wireless/hh3link.html
20 REPLIES 20
Distinguished Guru
Message 2 of 21
Re: How to use HH4 as a Slave hub?
It (the link) should work, but atm I've not checked to see if the info for the type a or type b works on the HH4.
If not, let us know and I'll take a look;)
-+-No longer a forum member-+-
Message 3 of 21
Done, it worked. The settings were a bit different in the HHB4 but it all works according to the guide.
Now I have a HHB4a being used as a slave to HHB3a. I am planning onto set this up for all the HHB4s we have. I haven't yet tested a HHB4 as a slave to HHB4 but once I get more stock, I will be doing that too.
Thank you DS.
Distinguished Guru
Message 4 of 21
Glad to hear it;)
a heads up - A HH3b as a slave is a PITA and may not work.
Hmm, A HH4a and a HH4a. That would be a good set up:)
Message 5 of 21
@DS wrote:
Glad to hear it;)
the only issue is that the HH4a is now stuck showing orange light for both the broadband and power. I am using the slave HH4 with a powerline adapter, I don't mind the orange lights but I would be glad if there was a fix for it.
Message 6 of 21
Black insulation tape, it works on my car engine warning light!
Distinguished Guru
Message 7 of 21
I'd of only expected a BB light, not a power one too on the HH4:(
I say expected, but IMHO the lights shouldn't be there unless there is a fault - the wireless light does go amber if we manually turn of either 5GHz or 2.4GHz:(
I have thought about putting some tape on the inside of the front cover to hide the wireless light....:|, but that's not practical for the average user.
edit. Not that I've already opened one to have a look around;)
Message 8 of 21
I personally don't mind the lights, as long as it works, lights don't matter.
Distinguished Guru
Message 9 of 21
But I'm like a moth, I'm drawn to the lights!:D
Message 10 of 21
After messing around with my router for hours, I have worked this much out. You have to have a cable inserted in the wan port, only that way the blinking orange light for power goes away.
