Distinguished Guru
Message 11 of 21
Re: How to use HH4 as a Slave hub?
@Reddit wrote:
@DS wrote:
But I'm like a moth, I'm drawn to the lights!:D
After messing around with my router for hours, I have worked this much out. You have to have a cable inserted in the wan port, only that way the blinking orange light for power goes away.
From one hub to the other hub (as you should) or from the slave to another device?
-+-No longer a forum member-+-
Message 12 of 21
from slave to another device.
Anyone interested in this thread can watch this 5 second video:
https://www.dropbox.com/s/djbtf6j49suh7ky/20130619_201638.mp4
Distinguished Guru
Message 13 of 21
So the power light stays red and the BB light flashes all of the time?
Message 14 of 21
yeah you are right the BB light does flashes all the time with orange colour and the power light stays orange too. The only way the BB light goes away is by inserting the wan cable but since its a slave hub, that won't be of any use.
Distinguished Guru
Message 15 of 21
Ok. Not sure what will happen, but if you use one cable and connect it from the slave back in to the slave (so 3 ports are used in total on the slave), was does the light do now?
Message 16 of 21
give me 3 minute , I will be back with the results.
Distinguished Guru
Message 17 of 21
So if I see a huge mushroom cloud somewhere over the UK, then I'll know it didn't work!:D
Message 18 of 21
nothing happened, I watched the router and the ports, no change whatsoever.
The HH4 did start to spark a little afterwards, then I could smell something burning around the router. I suspect that the chips might have been burnt, I will have to now do an autopsy of this router.
Tags (2)
Distinguished Guru
Message 19 of 21
I wasn't expecting to hear that!:(
(Say nothing when you call BT. It's still under warranty (as long as there's no sign of tampering with it)).
Message 20 of 21
Since the HH4 couldn't produce a mushroom cloud, I thought a different joke could do 😉
