Message 1 of 5
How would I request a DLM Reset for FTTC?
My DLM is restricting my line to 23mb/s and I would like to know how to reset it. Do I have to contact BT and will they do it remotely?
4 REPLIES 4
Message 2 of 5
Re: How would I request a DLM Reset for FTTC?
Just have patience, as explained previously, DLM will intervene automatically. There is no way to get a DLM reset with the figures you posted previously.
Message 3 of 5
A DLM reset wouldn't help in your situation in any case. DLM resets put the noise margin at 6dB, the 3dB margin is only achieved after DLM monitors the line for a period of time after the reset.
Message 4 of 5
Thank you for your response. I was just wondering as when I had Sky I had 34 mb/s.
Message 5 of 5
you just need to wait and ensure that your connection remains stable no resets or drops in connection
