mellow
Message 1 of 3
Hub 3 MAC code
Under my Hub3, along with other passwords, I see one code mentioned as MAC. Is it the MAC I'll need if I wanna switch from BT to another provider?
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Hub 3 MAC code
No.
The MAC address that you're refering (under the hub3) to is a Media Access Control
The MAC code, what is sometimes needed to switch ISP, is a Migration Authorisation Code
-+-No longer a forum member-+-
mellow
Message 3 of 3
Re: Hub 3 MAC code
Thanks DS...I thought it was odd to put the MAC code there...lol
