mellorij
Message 1 of 3
Hub 3 software update failing
OK, I have now officially given up with my Hub 5, due to it rebooting so much. I have put back my Openreach modem and Hub 3.
However it keeps failing the new firnaware download, any ideas....
  10:53:31,28 Dec.CWMP:Event code:7 TRANSFER COMPLETE, Status:Download failure
  10:53:31,28 Dec.CWMP:session completed successfully
  10:53:30,28 Dec.CWMP:session start now, server:https://pbthdm.bt.mo, Event code:, M Download
  10:53:29,28 Dec.CWMP:DownLoad File, File type:1 Firmware Upgrade Image, File Name:pbt/firmware/HomeHub3V100R001C01B036SP05/HomeHub3V100R001C01B036SP05_L_B_encrypt.signed_fix
  10:53:29,28 Dec.CWMP:DownLoad File start
  10:53:27,28 Dec.CWMP:session completed successfully
  10:53:26,28 Dec.CWMP:session start now, server:https://pbthdm.bt.mo, Event code:, 6 CONNECTION REQUEST
2 REPLIES 2
gg30340
Message 2 of 3
Re: Hub 3 software update failing
You could try a factory reset of the Homehub 3 by pressing a pin into the recess button on the rear for about 20 seconds.
Alternatively you could use the Homehub 5 as a router connected to the Openreach modem if you still want to have the dual band wireless and the 4 GigE ports that the HH5 has. This does away with the VDSL modem connection of the HH5 which would appear to cause the reboots.
mellorij
Message 3 of 3
Thanks for your suggestions, I have unfortuntely already tried both with no luck.
Regards
Ian
