robh66
Message 1 of 2
Hub 5 Resets
How many resets are needed before BT will investigate a possible faulty DSLAM, as in the past 24 hours the hub has reset 15 times, and that started at 5.25am on Weds morning.
I've got a new Hub 5 and prior to that it ran for 10 days without a hitch.
1 REPLY 1
imjolly
Message 2 of 2
Re: Hub 5 Resets
More likely a faulty hub. Have you tried a factory reset of the hub and see if that helps stabilise the connection
