bmelsom
Message 1 of 10
Hub 6 separate bands problem
I have separated  the 2 bands (& saved result) but I cannot see the 5ghz option on any mobile devive (Apple & Panasonic). Worked fine with Hub 4. Any thoughts please?
9 REPLIES 9
imjolly
Message 2 of 10
Re: Hub 6 separate bands problem
try a factory reset of the hub only once and then using the toggle switch in HH6 juat move to separate and asee if you can see networks now  remember to turn of smart setup after factory reset
bmelsom
Message 3 of 10
Tried that to no aviail
I'm thinking it has something to do with the Hub Manager.
I'm having problemms with this, It will not lawyas recognise the password despite it being correct, the save "spinner" seems endless, and whn I try to turn off smart set up I get a greyed out sceen showing its off but I cannot  click save and have to leave the page and start over!
Deeply frustrating
bmelsom
Message 4 of 10
CRACKED IT.
For some reason Hub Manager wasn't wroking proper;y with Safari. I used Chrome and now all is OK I can see the separate bands.
bmelsom
Message 5 of 10
Spoke too soon. Having altered the settings, I lost the 2.4 connections. Given up and reset to the original settings
bmelsom
Message 6 of 10
Spoke too soon. The 5 ghz wokrd fine, but I could not connect the 2.4. Given up and gone back to defaults.
bmelsom
Message 7 of 10
not solved after all see last post.
imjolly
Message 8 of 10
go to message 4 then options on right and remove solved marker
RobbieMac
Moderator
Moderator
Message 9 of 10
Hi @bmelsom
I have unmarked post 4 as the accepted solution for you.
Cheers,
Robbie
bmelsom
Message 10 of 10
thank you
