Hoobs
Message 1 of 5
Hub Phone
I heard that if you dial 5 before dialling the number it will use your landline instead of BBtalk.
If that is the case are the minutes included with your landline plan?
cheers guys, only just got the thing 😉
4 REPLIES 4
smev
Message 2 of 5
Re: Hub Phone
Dialling 5 on the hub phone is just the same as using your ordinary landline phone, and will be billed as a landline call.
Distinguished Guru
Message 3 of 5
Re: Hub Phone
and yes, you would be on the normal calling plan for calls
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
aidanmack
Newbie
Message 4 of 5
Re: Hub Phone
Is there away of making the hub dial out on the landline by default? Or do I have to put a 5 before every number in my address book?
Distinguished Guru
Message 5 of 5
Re: Hub Phone
I think that has been tried before and didnot work
