Lam
Message 1 of 6
Hub doesn't recognize key
I called BT who were useless; after numerous tests they're sending a new Hub. No explanation and now I have no internet connection for 4 days. I have never experienced such atrocious customer service.
5 REPLIES 5
imjolly
Message 2 of 6
Re: Hub doesn't recognize key
which key - admin password or wireless
did you do factory reset holding recessed button on back and the lights flashed?
Lam
Message 3 of 6
Yes I pressed the recessed button and it still doesn't work.
It was the wireless key
imjolly
Message 4 of 6
if you know admin password then connect with ethernet cable then enter hub manager and check wireless password and change it to something else
don't even need internet connection
gg30340
Message 5 of 6
Just a basic check: You connect to the Homehub SSid (Name) which should be something like BTHomehub5-xxxx then enter the wireless passkey which is found on the label on the Homehub.
Lam
Message 6 of 6
Thanks! This worked.
