ellemcee
Message 11 of 19
Re: Hub internet light goes out/connection drops and some slow speed problems
My menu looks different to yours - basic config is extra menu item - software version 6.2.6.H which I assume is old and maybe needs updated. After Thursdays factory reset I've had to reset the password, but this screen still won't let me navigate anywhere else without the password pop-up appearing - don't know what the username is either - admin?
Apologies if I'm being thick - I'm usually much better than this and can usually work it out on my own.
Message 12 of 19
You need to look at the advanced settings - Status - ADSL line - Details . I am surprised that the link I gave you did not take you there.
Mine is the original 6.2.2.6 firmware, maybe they changed the menu layout?
ellemcee
Message 13 of 19
Here are the stats although I'm not sure what they mean - beyond me I'm afraid. Nothing labelled Noise as in the other post, but presume I'm looking at the S/N one?In which case the difference is 4
I just lost my internet again there whilst I was trying to reply, and now I'm back to dial up page load speeds again - *sigh*.
Message 14 of 19
Its the S/N margin (down) that`s of interest.
There are lots of corrected (FEC) and uncorrected (CRC) errors, which means that you line is really working beyond its limits, at the speed you are connecting at.
The 5.5 db margin is probably not enough to maintain a stable connection, as there is probably quite a bit of random noise getting in somewhere.
Assuming that you have checked all your wiring to make sure that there are no extensions picking up noise, you could try plugging it into the master socket, or test socket (if you have one) to see if you can get a higher margin.
You could try power cycling the hub first of all, to see if the margin increases.
Otherwise you could try disconnecting the ADSL lead at the microfilter a few times, leaving it out for about 10 seconds at a time, and see if the margin increases when the broadband connection restores.
The instructions and reasoning behind them, were in the link I posted.
Message 15 of 19
maybe changing to interleaving will help stabilise your line   strange a lot of FEC errors on fast normal that would be nil or very low
ellemcee
Message 16 of 19
Thank you for all the help today - I really appreciate it!
I'm going to have to leave it for today, but will pick up the threads during the week when I have a bit more time. I'll look into the interleaving too as not sure what this is.
Hope you won't mind if I have a few more questions!
Message 17 of 19
FEC and Interleaving are normally switched on together, unless the DLM is having a bad day Smiley Wink
Message 18 of 19
You cannot turn interleaving on yourself.
Message 19 of 19
that was my point so maybe getting back to interleaving will help - DLM must be having a bad day with fast/fec errorsSmiley Wink
