borley
Message 1 of 2
Hub manager saying i have nothing connected to it!
As title says, in one of my other posts someone said look at the speed of my ports as i`m having problems with my broadband. Well i looked and under the wireless,ethernet options it says no devices detected yet i`m using the broadband as we write, any help apreciated.
Regards
Guy
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: Hub manager saying i have nothing connected to it!
This can happen for no apparent reason. A power cycle of the hub can restore the device on the hubs home network page.
If you have altered the hub settings and it's configured to issue a static IP address to your device, then it should be showing
but
If you have the device set to a static IP address, then the hub won't show it on the hubs network page.
-+-No longer a forum member-+-
