mycool
Message 1 of 6
Hub not visible
Hi, I recently moved to a property with a BT Home Hub 2.0. The problem is that my laptop (Windows 7) doesn't see wireless network from our hub (it sees other bt hubs from neighbours though) so I can't connect. My phone (Android) and my friend's laptop (Windows 😎 see our network and connect without a problem. Please help!
5 REPLIES 5
pottyperson
Distinguished Guru
Distinguished Guru
Message 2 of 6
Re: Hub not visible
Welcome to the forum. I assume you're a BT broadband customer. Have you inherited the hub? I'm speaking from memory and stand to be corrected, but I think wireless can be turned off as long as the owner isn't opted in to BT Wi-Fi. So you need to check that. If wifi is not switched off the hub could be faulty. Does it work with an ethernet connection?
mycool
Message 3 of 6
Re: Hub not visible
Hi,
I joined shared accomodation.
The hub has wifi on, I can access it through my Android phone, my flatmate also has an access with her Windows 8 laptop. Only my Windows 7 laptop doesn't see our hub's wifi (but sees other bt hubs from other houses) but that's the computer I need to use 😕
mycool
Message 4 of 6
Re: Hub not visible
Ethernet works, but I need wifi connection...
imjolly
Message 5 of 6
Re: Hub not visible
have you tried updating your wifi card driver from manufacturer's website and not rely on windows update
mycool
Message 6 of 6
Re: Hub not visible
This didn't help. The only working solution came from BT tweeter, not this forum. I just switched channel on bt hub on different, less occupied frequency. Easy, peasy, lemon squeeze!
