Mooly
Message 11 of 72
Re: Hub3 + Modem site specific connection issues following W10 Creators Update.
The problem has appeared again.
gg30340
Message 12 of 72
Have you tried a different browser?
Liam_
Recognised Expert
Message 13 of 72
@Mooly
Apparently W10 Creators Update can cause issues with Edge and other Internet connection issues.  About par for the course with some Win 10 updates.
Mooly
Message 14 of 72
Yes, Internet Explorer. All seems fine with that on the problem site.
The problem struck again this morning and I tried a couple of things that didn't involve altering anything on the Hub, although I had no luck with correcting the issue. IE was fine. Back to Edge and still faulty. I then left things idling (no  browser open) for 25 minutes and found on return that Edge was back to speed again.
I don't understand enough about how a PC interacts with a router (and vice versa) to get a handle on what could be occuring here. For example why just an odd site affected ?
licquorice
Message 15 of 72
If it works with IE and not Edge, the problem is clearly with Edge and nothing to do with your router. Personally, I wouldn't use either.
Mooly
Message 16 of 72
I can't argue with the basic logic of that, and yet I certainly wouldn't bet on it. Stranger things have happened. Perhaps the latest version of 10 is 'incompatable' in some way. There are certainly no other reports of access issues on the site concerned, and its a truly global concern with 400,000 members.
One thing. My Hub 3 is the 'Type A' and is running this firmware:
4.7.5.1.83.8.94.1.52 (Type A)
Liam_
Recognised Expert
Message 17 of 72
@Mooly
You really should give a good browser a try.  After getting fed up with the very flaky Internet Explorer in the 90s began using Netscape Navigator.  A vast improvement.  Then Phoenix when it appeared, that became Firefox and been using Firefox then the 64Bit derivative Waterfox ever since.
Never have any issues reaching any sites, unless of course the site itself actually has a problem.
licquorice
Message 18 of 72
@MoolyThe Hub is totally agnostic to the Operating System of your device let alone which browser you are using on it.
gg30340
Message 19 of 72
The problem has nothing to do with your hub or BT. If the problem only happens when using Edge and has only happened since you did a Windows 10 update the problem has to be with Microsoft. It is either Edge or Windows 10 causing the problem. As IE works OK and I suspect so will Chrome, Firefox and Opera browsers that only leaves Edge being the problem.
One thing to try, in case you haven't already, and that is to carry out a re-start of your computer not a shut down and start. This can allow the Windows 10 updates to install correctly.
Mooly
Message 20 of 72
Yes, I regularly do restarts as part of general housekeeping to keep the file system in good order. This problem appeared on the upgrade install initially, and then on my clean install.
I'll do some more research and see what I can come up with... and update this thread of course with any outcomes.
