davidramsay
Message 1 of 7
I am getting Remote Administration and Port Forwarding in the event log on my HH4
The following is a small sample of the events;
12:36:57, 07 Jan.IN: BLOCK [16] Remote administration (TCP [169.229.3.90]:41590-​>[86.186.72.110]:80 on ppp1)
12:36:03, 07 Jan.IN: BLOCK [16] Remote administration (TCP [119.133.54.46]:50876-​>[86.186.72.110]:8080 on ppp1)
... using the tools I have available it seems that they originate from across the world.  I know they are blocked but ...
I am also getting the following port forwarding events shortly after my device connects, I have not implemented these rules;
12:25:27, 07 Jan.(44473.080000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>4500, internal ports: 4500, internal client: 192.168.1.64
12:25:26, 07 Jan.(44472.720000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>5353, internal ports: 5353, internal client: 192.168.1.64
12:25:26, 07 Jan.(44472.090000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>4500, internal ports: 4500, internal client: 192.168.1.64
12:25:25, 07 Jan.(44471.660000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>5353, internal ports: 5353, internal client: 192.168.1.64
12:25:24, 07 Jan.(44470.020000) Lease for IP 192.168.1.64 renewed by host DavidRaaysi7MBP (MAC 14:10:9f:de:8d:61). Lease duration: 1440 min
... any advice appreciated.
6 REPLIES 6
licquorice
Message 2 of 7
Re: I am getting Remote Administration and Port Forwarding in the event log on my HH4
Are you using a VPN and possibly Apple TV?
davidramsay
Message 3 of 7
Neither, although I do have VMWare Fusion installed but not running, WiFi is currently the only configured network device.
licquorice
Message 4 of 7
I would disable UPnP in that case.
davidramsay
Message 5 of 7
Nope cannot do that as I require it for remote connection to support my disabled Son and his iMac
licquorice
Message 6 of 7
In which case, that is probably what is causing UPnP to open the ports and there is no problem.
davidramsay
Message 7 of 7
As the session isn't running and I haven't used it for at least a week then ...
Anyway will do some more testing thanks
