Message 1 of 5
I cannot get BTINTERNET mail to work on OUTLOOK on laptop but OK on OUTLOOK on the desktop
I have BTInternet EMail working in OUTLOOK on the desktop (IMAP)
But I cannot get it to work again (it used to) on the laptop with either IMAP or POP3.  I have tried comparing settings and they seem to the dame.
It fail to connect when I run the Test Message.
Any idea?
MB
4 REPLIES 4
Message 2 of 5
Re: I cannot get BTINTERNET mail to work on OUTLOOK on laptop but OK on OUTLOOK on the desktop
Working now after a few more failed attempts.
I turned off the VPN and able to set up and send and receive mail.  But I can still send and receive with the VPN back on!
MB
Message 3 of 5
Hard to be sure but I quite often see that OUTLOOK is failing to connect to the BTINTERNET server.  I turn off VPN and it connects OK but I can then turn VPN back on and it still connects.
MB
Message 4 of 5
The issue would then seem to be the VPN. It depends where in the world your VPN wants to connect (unless you do specify a country). There have been many reports of email access problems from various places around the world.
Message 5 of 5
It is the Norton VPN and normally set to the UK.
Now that I have BTINTERNET working on Outlook again, I see a failure to log on each morning soon after switching on the laptop.  I turn off the VPN and all is OK.
MB
