mclarenrob2
Message 1 of 16
I give up on BT.
Broadband has been running at 0.10mbps for a month now. Two engineer visits , one fixed a fault (he said) nd the other just reset the dlm.
We used to get 3.5mbps. The ip profile is currently 0.14
DSL uptime: 0 days, 00:45:45
6. Data rate: 448 / 5856
7. Maximum data rate: 1116 / 5984
8. Noise margin: 20.0 / 6.0
9. Line attenuation: 29.0 / 45.5
10. Signal attenuation: 29.0 / 47.0
15 REPLIES 15
Webby
Message 2 of 16
Re: I give up on BT.
Your IP profile should be around 5meg with that connection rate. Have you called the helpdesk and requested a reset?
mclarenrob2
Message 3 of 16
Yes , the engineer came and did it and I asked someone on live chat to do it also. It hasn't changed since, the hub has been on all the time except when it's dropped connection by itself...
john46
Message 4 of 16
if your connection is dropping then your IP profile will not increase or remain stable resetting your profile is point less if the connection is not stable
mclarenrob2
Message 5 of 16
So it's a fault on the line then.
It's a long line and I understand the difficulties with the length but we have had 3.5meg and that's usable.
Every time an engineer comes they can't find any faults though
We are having a community fund to get FTTP but that's 6-12 months away 😞
john46
Message 6 of 16
have you tried connecting to the test socket
mclarenrob2
Message 7 of 16
Yes. I don't think it's our problem as two engineers have checked it out.
john46
Message 8 of 16
all you can do is persist with the engineers until it gets resolved
mclarenrob2
Message 9 of 16
Awaiting a call from Mumbai this afternoon so they'll probably send another poor engineer , I almost feel sorry for them coming to this line!
john46
Message 10 of 16
it is the only way to resolve the problem
