Newbie
Message 21 of 25
Re: I have 2x Home Hub 5's, can i use my 2nd Home Hub 5 as a repeater/slave?
Thanks for your help its all up and running at the moment....the dead spots are now alive!!!!
Message 22 of 25
Am getting the new BT hub tomorrow (the 6 - whatever their latest one is?) and am hoping to use my old 5 in this way.  Does it work if they aren’t the same model.
on a related note is there a device which works as a multi port Ethernet switch (fed via Ethernet cable from my hub AND as a Wi-fi extender as one of the replies above suggests a dedicated device might be better than using an old router?
Message 23 of 25
@Richj1608 wrote:
Am getting the new BT hub tomorrow (the 6 - whatever their latest one is?) and am hoping to use my old 5 in this way.  Does it work if they aren’t the same model. Yes, no problem at all.
on a related note is there a device which works as a multi port Ethernet switch (fed via Ethernet cable from my hub AND as a Wi-fi extender as one of the replies above suggests a dedicated device might be better than using an old router? Yes, the  Edimax EW-7228APn is one such device, there are others.
Message 24 of 25
@Keith_Beddoe wrote:
This guide will tell you how. Although it for the HH3, the same applies to other home hubs.
http://forumhelp.dyndns.info/wireless/hh3link.html
You will need to run an Ethernet cable.
Hi, I have just clicked the link with the instructions and they do t appear to be there (it links to a BT ad?)
is the link link no longer valid, or am I missing something?
Message 25 of 25
The link is a very old link, I have now removed it from my website.
Look on the Forumhelp website under "Wireless problems" and you should find what you are looking for.
