JohnHatter
Message 1 of 3
I have YouVoiew box and BT Vision Silver box
The old silver box has an ESPN card, I know I cant have both boxes in use at the same time, but can I unplug the Youview box and fire up the silver box just for sport through the aerial ?
Then go back to youview for normal viewing?
2 REPLIES 2
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: I have YouVoiew box and BT Vision Silver box
I would have thought the viewing card would only work if BT kept it enabled i- if you have a Youview from BT contract I can't see them continuing to activate an old viewing card. Plus I suspect for the sport options the card would require being paired to your official BT box.
notoriousdbp
Recognised Expert
Message 3 of 3
I think the silver boxes are pretty much obsolete now. You can always try but I doubt you'll get any joy
---Remember to mark as 'solved' and give stars when you like a post---
