Mana
Message 11 of 23
Re: I now have a VDSL2 profile 17a and upto 50Mb ??
still on the 17a?
Sage
Sage
Message 12 of 23
The attainable rate shows that he is still on 17a.
sixdoublesix
Message 13 of 23
My exchange is going to be enabled in 3 weeks and I want to make sure I get the fastest speeds, would any of these be suitable for increasing speeds?
DrayTek Vigor 2850n
Netgear DGND3700
Distinguished Guru
Message 14 of 23
Whatever you buy, you cannot get more than what your line is capable off.
if you are going to buy a router or modem/router, then buy it for what it can offer you, like better wireless, more security features, the ability to use different dns servers, port forwarding, even price.
toekneem
(EASBF)
deathaxe
Expert
Message 15 of 23
As said above the line will go as fast as it can, although a lot of us have seen the speeds move all over the place in the first month or so and settle down.
There is a very good buffalo airstation avalible for £25 which does the job as a FTTC router it just doesn't have gigabit ethernet or 5Ghz wireless N.
You need to work out what you need the thing to do and then work out what bit of kit will get you that.
I got something top end as I needed to use quite a lot of advanced features which the HH3 didn't offer.
jimmy2bob
Message 16 of 23
Sorry for the total noob question, but I've spent ages trying to find my stats - where do I go to find them? Thanks!
PC
Recognised Expert
Message 17 of 23
Hi Jimmy
Don't apologise It's BT that should be apologising.... Smiley Happy
Why??? Because with the White Openreach Modem and the HomeHub3 they supply you can't get access to any stats.
The only thing you can do is get the IP Profile for your line by running the FTTC part on http://www.speedtester.bt.com/
That will tell you the max speed your set to.
Some people that have replaced the HH3 at their own cost have access to their stats.
Please Click On any Text in Blue as that automatically links to information.
PC (NDEGR)
jimmy2bob
Message 18 of 23
Ah!  That makes total sense:
I did the BT test and dont think I'm getting the best I can
> Download speedachieved during the test was - 18214 Kbps
 For your connection, the acceptable range of speedsis 12000-38710 Kbps .
 Additional Information:
 IP Profile for your line is -38710 Kbps
>Upload speed achieved during the test was - 8622 Kbps
 Upstream Rate IP profile on your line is - 10000 Kbps
Will call BT on Monday and see what can be done.
Hate being new!!
Thank you
Distinguished Guru
Message 19 of 23
How long have you had Infinity and are you connecting via wires or wireless
toekneem
(EASBF)
jimmy2bob
Message 20 of 23
Since Thursday and the test was done wired
Thanks!
