pilot1
Message 1 of 5
I phone connecting to BT Fon instead of hub
Can anyone help when i power up my iphone each morning it goes to BT Fon instead of my home hub. I then have to go into settings on phone and tick hub. How do i make that my default?
4 REPLIES 4
Message 2 of 5
Re: I phone connecting to BT Fon instead of hub
When it's connected to FON, click the blue arrow on the right hand side and press the "forget this network" button at the top.
Problem solved 😉
pilot1
Message 3 of 5
Thanks for your prompt and helpful reply.
Sham
Message 4 of 5
Also if you subscribe to btfon there is a iphone app for btfon, this means you can use it to auto connect to btfon and openzone when out and about, full instructions given when you install it
MakemLad
Newbie
Message 5 of 5
I had this problem & found out that it is an iPhone problem as Apple don't allow you to set a prefered wifi order. Instead it lists them in alphabetical order & connects to the first available one in the list.
I have changed my hub name to one starting with A so it is listed above both fon & openzone. That way I don't have to keep changing settings every time I get home.
