Message 1 of 30
IMAP a Bt email address
I have three email addresses with BT  I cannot set up one of them on iMac or iPad message states cannot verify password. The password is correct. The other two email addresses work fine on iMac and iPad BT cannot resolve the problem Any help would be appreciated.
29 REPLIES 29
Message 2 of 30
Re: IMAP a Bt email address
Hi @EJA,
Welcome to the Community. I am sorry to hear that you can't get 1 of your 3 email addresses set up on your iOS devices.
Are you trying to set them up using our BT Email app or are you trying to use the devices own email app?
DanielS
Message 3 of 30
Hi Daniel
l am trying to use the iOS app and the bit webmail. The other two email accounts work fine so did the other account until 1 month ago.
I have spent five hours on the phone to BT a waste of time. I see on the community forum this is a common problem but there does not seem to be an answer. I have changed the password five times. One other account has the same password and that is ok.
Thanks for interest
Message 4 of 30
So - you can access this email address via webmail? It's just that using an app on your devices doesn't work?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 5 of 30
Hi stevebrass
The email account in question I can only get by going to MY BT I cannot get it on any app
EJA
Message 6 of 30
it would be worth changing the password for the email account that is giving the problem via My BT then attempt to set it up again on your devices.
Message 7 of 30
If your email account is working on one or more of your devices then I would not recommend changing the password, this forum is full of tales of woe from those who did.
Try changing the server name on the Apple devices from mail.btinternet.com to imap.btinternet.com
Please help the community to help you by including all relevant information, single word responses may be quick to type but they offer little value to this Community Forum and do not help its team of volunteer members to help you.
Message 8 of 30
I have changed the password 3 times on MY BT it has made no dffrence
Message 9 of 30
Hi Les-Gibson
Thanks for the advice, I will try tomorrow
Message 10 of 30
Hi Les-Gibson
I have tried using the imap.btinternet.com but did not work. I get the message imap.btinternet.com is not responding Verify that you have entered the correct account info in mail settings.
