Message 291 of 420
Re: INFINITY Netwrok wide Issues.. - IMPORTANT
re: Maidenhead. That's simply Speedtest determining the best performance server to run your test against. I'm in Lisburn, NI yet it picks Manchester for my test by default. You can go into the preferences on speedtest.net and save whichever server you want as your default for testing.
Note that your closet server may not be your quickest. For example, I find Kingston Upon Hull, London, and Maidenhead to generally be my fastest.
Message 292 of 420
Looks good here too, getting normal speeds again..
Message 293 of 420
Is there any chance of getting an explanation from BT as to what happened?
Expert
Message 294 of 420
Well, I am back up to full speed, so fairly happy. Though an explanation should be forthcoming from BT for the problems they caused AND the fact they so say were not aware of it.
Message 295 of 420
Back up to speeds for the moment
Message 296 of 420
back to full speed too. now only the msn issue to resolve
anyone else on infinity getting random disconnections from msn and other im clients ?
its definatelly the hub or connection causing it ive tried different pc's and get the same issues.
Message 297 of 420
BT still suck though!
Message 298 of 420
I'm seeing my speed test results drop down to around 15 to 20 meg right now (from my usual 32 meg which I was getting earlier this evening). Anybody else noticing a drop in speed test results?
Expert
Message 299 of 420
So far so good then 🙂 (still on 37mbps at the moment)
A lesson to be learned perhaps though; what was pretty much a PR disaster for BT could so easily have been avoided by being honest & keeping customers updated.
If the status service page (and phone lines) had said something like "there are currently major problems with Infinity nationwide but our engineers are working hard to resolve the issue, it will however be necessary to throttle speeds whilst repairs are being carried out to ensure a speedy resolution"  customers would at least know and would be far more understanding.
After all "It's good to talk" ....
Message 300 of 420
Just did a multi threaded download from Apple there as a quick test and was only getting 1.4MB per second instead of around 3.8MB that I would expect at full speed so definitely not running a full performance at the moment. Of course, network congestion could just be slowing things down temporarily. Let's wait and see..
