spar
Message 411 of 420
Re: INFINITY Network wide Issues.. - IMPORTANT
cherkhan
are u getting those speeds at peaktime and consistently?
Toejams
Message 412 of 420
I use Usernet, however I use Alt.Binz as a client.  No speed issues on Port 119.  Like you BT Infinity Option 2
cherkhan
Expert
Message 413 of 420
Yep, since Monday everything has been corrected as BT said they would be, though I thought they actually meant next monday. It appeared they pulled their finger out and got it sorted.
Something to do with a 'hot vp' at the Worle exchange. I understand they took control of my line and did a thorough test on it.
Works great now:)
Use the 'mods' on this site as it was them that forced this through. Though I did make a lot of complanits to billing, faults etc etc.
spar
Message 414 of 420
which mod did u deal with?
at present they are just issuing the standard send an enginner out to me
which will be utterly pointless. Added to that i have no time to book off.
also they wont be here at peak time, and the fact its fine off peak means it not an issue here at the enduser.
the fact it occurs at peak time points to the exchange at chrolton or futher down the infrastructure.
trying to convince them to check it properly isnt getting through at present.
it needs checking at peak time
had simialr issues at old place in early days of virgin, 8 engineers out to no avail, until i spoke to a director and what u know they had a problem in the core at bagley when they fixed that, voila no more issues.
history seems to be repeating itself with bt fttc.
cherkhan
Expert
Message 415 of 420
Craig took up my problems and I heard and dealt through Newcastle for the fault.
cherkhan
Expert
Message 416 of 420
Latest line check through speedtester.bt.com
Beat that then:) 🙂
1. Best Effort Test: -provides background information.
Download Speed
40980 Kbps
0 Kbps38717 Kbps
Max Achievable Speed
> Download speedachieved during the test was - 40980 Kbps
 For your connection, the acceptable range of speedsis 12000-38717 Kbps .
 Additional Information:
 IP Profile for your line is -38717 Kbps
2. Upstream Test: -provides background information.
Upload Speed
8115 Kbps
0 Kbps10000 Kbps
>Upload speed achieved during the test was - 8115 Kbps
 Upstream Rate IP profile on your line is - 10000 Kbps
DarrenA
Message 417 of 420
Lol.
Well, I can beat you upload rate Cherkhan...
...but I think I've got a way to go before my download rate is on par!
andybird456
Message 418 of 420
I for one have had enough.
To add insult to injury BT are now throttling online gaming so I can't even play computer games in the evenings (and I sure as **bleep** can't want TV or a movie on it).
I just want it gone so I can go back to the slightly flakey 4mb service I used to have... at least when it was working it did everything I wanted and it was really obvious when something was wrong because it didn't work at all, but only for a day or two... this is over 3 weeks.
doubler
Newbie
Message 419 of 420
It's happened to me on quite a few occassions now. 1 meg down 8 meg up.
Just phoned BT but I hung up after a minute, I can't face going through some standard fault finding sheets when I know it's an issue with the exchange not my settings 😞
Anybody have a direct number or email to someone who knows the situation & can do something about it. I'll email Craig firstly as he has kindly offered to help out with this issue.
Message 420 of 420
Re: INFINITY Netwrok wide Issues.. - IMPORTANT
Hi Please note you would be better of starting your own thread on the infinity boards you willl get more help there rather then adding it to a thread that had been inactive for 10 months
