alphanumeric
Message 1 of 6
INTERNET SECURITY WARNING
I use a BT Internet Server.
Today while using Windows Live Mail i received the following screen pop up message:
The server you are connected to is using a security
certificate that could not be verified.
A certificate chain processed, but terminated in a
root certificate which is not trusted by the trust
provider.
Do you want to contiue using the server?
         YES         NO
What on earth is this: has anybody out there also received it?
For now, i clicked YES, and pending an explanation am hoping for the best.
Thank you, alphanumeric.
Tags (2)
5 REPLIES 5
Webby
Message 2 of 6
Re: INTERNET SECURITY WARNING
It's just a windows warning, don't sweat it.
4KMarty
Message 3 of 6
provider.
         YES         NO
As Webby say, it's a WIndows warning - nothing to do with BT or BT Internet.
alphanumeric
Message 4 of 6
Hi. Webby. Thanks for your response. Not too sure why Windows gave such a warning.
Cheers, alphanumeric.
alphanumeric
Message 5 of 6
Hi. 4KMarty. Thanks for your response. Not sure why Windows sent such a warning.
Webby
Message 6 of 6
It's just when it thinks a site doesn't have a valid security certificate. It's nothing to worry about.
