glasgowlegalsec
Message 1 of 4
IP Address
Can someone help?  My broadband wi-fi connection is working but not on all my devices.  My 7" android tablet is connected, as is my Sky On Demand.  However, my laptop has now lost its wi-fi connection completely and my new 10" android tablet won't connect via wi-fi at all. It authentices the router but then when it tries to search for an IP address it just continues to search and hangs - it doesn't find an IP address so cannot connect via wi-fi. I thought about perhaps turning off the router for a couple of minutes and turning back on to see whether my laptop and new tablet would then be able to find an IP address and then connect by wifi.  However, I am a concerned that if I switch off the router I'll lose the wi-fi connection I currently have to for my 7" table and Sky On Demand.   Can anyone advise whether this is the case and/or offer any advice on what I could do?   I'm a bit of a technophobe so not very good at this sort of thing! Thanks  PS - at the very must we only use a maximum of 2 devices at a time via wi-fi.
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: IP Address
Assuming you have a HH4 or HH5.
Try turning Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Also try separating the SSIDs.
http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
Devices where there are known to be problems include:
    • Some Apple devices including iPhone 5 and Apple TV
    • some Android smartphones
    • Xbox<
glasgowlegalsec
Message 3 of 4
Re: IP Address
Thanks, but I have a HH3.  Will your previous advice still apply?
Keith_Beddoe
Message 4 of 4
Re: IP Address
No,
Instead do a factory reset of the HH3 and see if it helps.
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-home-hub-to-its-factory-...
