Message 1 of 3
IP Phone issues with Home Hub 5 & Infinity
Hi,
I am hoping someone can help with this issue.
I have an IP phone that I use to work from home that is part of my companies Phone system.
I have used this phone successfully through other Broadband suppliers and it still does. I also help configure them for other home workers so I generally find a way to get them working.
I have recently moved and we now have a BT Home Hub 5 with Infinity. Additionally my company have a BT Business Hub 5 so I generally know my way around the device. I have the phone setup and have also opened ports that I normally open when setting the IP phones up for our other home workers to no success. The phone gets an IP (I have also tried static) from the HH5 but I get a SIP error "SIP Server Not Found". I have had this issue before and have always disabled SIP ALG in the home workers router which normally fixes the issue. I know this setting exists in the business version of the hub because i can access it at work, however the home hub does not have this setting (unless it does and it is hidden).
Has anyone had a similar issue? does anyone know if it is SIP ALG and if so how to turn it off?
Any suggestions would be great.
Thanks in advance
2 REPLIES 2
Message 2 of 3
Re: IP Phone issues with Home Hub 5 & Infinity
The HH5 is much more locked down than the business Hub.
Message 3 of 3
I would have thought there would still be a way of accessing it or changing it.
I can understand why things are hidden etc.
