Message 1 of 2
IP Phone
Hi
I have a home hub 2 which had a firmware upgrade to v8.1.H.U (Type A) applied on 19/8/11. Since then I've not been able to use the normal telephone line (green socket). How do I revert back to the earlier firmware version?
I have a BT home hub 2 to which I have connected a polycom phone using the green socket at the back of the home hub to make IP calls. The hub firmware was upgraded on 19/8/11 to V 8.1.H.U (Type A) since that upgrade the external phone (green socket) has stopped working. I have a BT wireless phone, which was supplied with the hub, that I can also use to make IP calls, this is working ok.
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: IP Phone
Hi
If you are trying to use an IP phone into the green socket it will not work as that is where you would plug a standard PSTN phone.
In order for an IP phone to work you will need to plug it into one of the yellow sockets.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
