goral
Message 1 of 9
IP Profile 8000 max speed 3700!
Hi, it is normal have IP Profile 8000 but speed just 3700?
If I reset BT Hub it will be help?
Or just order engineer?
Speed test and ADSL line status
1. Best Effort Test: -provides background information.
    Download Speed
    3738 Kbps
0 Kbps    7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 3738 Kbps
 For your connection, the acceptable range of speedsis 2000-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :10424 Kbps(DOWN-STREAM), 944 Kbps(UP-STREAM)
 IP Profile for your line is - 8000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 16.63:15.04:68.33 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
    Upload Speed
    742 Kbps
0 Kbps    944 Kbps
>Upload speed achieved during the test was - 742 Kbps
 Upstream Rate IP profile on your line is - 944 Kbps
ADSL line status
Connection information
Line state    Connected
Connection time    19 days, 9:59:47
Downstream    10,426 Kbps
Upstream    944 Kbps
ADSL settings
VPI/VCI    0/38
Type    PPPoA
Modulation    ITU-T G.992.5
Latency type    Interleaved
Noise margin (Down/Up)    8.5 dB / 5.0 dB
Line attenuation (Down/Up)    31.0 dB / 15.5 dB
Output power (Down/Up)    20.9 dBm / 12.4 dBm
Loss of Framing (Local)    0
Loss of Signal (Local)    0
Loss of Power (Local)    0
FEC Errors (Down/Up)    1644446 / 7973
CRC Errors (Down/Up)    758 / 2147480000
HEC Errors (Down/Up)    nil / 76958
Error Seconds (Local)    548
8 REPLIES 8
chris6273
Recognised Expert
Message 2 of 9
Re: IP Profile 8000 max speed 3700!
Hi goral,
It seems like there may be a bit of congestion tonight on your exchange (My exchange has suffered from it aswell I believe) which may be the reason for slower throughput.
Any chance you can do another test after midnight when the peak period is over?
___________________________________
Like this post? Give it a Star :D. If this post answers your question, please Mark it as the Accepted Solution.
Message 3 of 9
your download speed should be far better but need to check your exchange for congestion  try here
http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
goral
Message 4 of 9
I made test about 1 AM result this same.
I check exchange status from this 3 links and is nothing about my exchange, there is nothing close...
I still get only 3,5 MB/s.
Can I order an engineer?
Or try reset BT Hub?
Message 5 of 9
resetting the hub won't help.  If it's still like that today then I would send an email to the mods for assistance giving your account and phone number and a link back to this thread  forum.moderation.team@bt.com
goral
Message 6 of 9
Yes is still this same.
Test result from about 9:30 13.01.11
Is nearly identical like this from yesterday and from day after...
    Download Speed
    3720 Kbps
0 Kbps    7150 Kbps
 Download speedachieved during the test was - 3720 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 4.44:34.01:61.55 (SBE:NBE:PBE)
    Upload Speed
    699 Kbps
0 Kbps    944 Kbps
>Upload speed achieved during the test was - 699 Kbps
Message 7 of 9
I would send the email to the mods
Moderator-Retired
Message 8 of 9
Hi Guys,
Whilst I understand that a throughput speed that is about half of the IP profile is disappointing its not really evidence of a fault on the line.  As was suggested earlier it could just be a bit of higher congestion than what you have noticed before.
In order for the mod team to investigate a potnetial fault we would need to see a much lower reading to bring a case to our supplier.  I would recommend running speed tests over the next week, morning and evening if possible, and recording the results.  If you see a further drop in speed post up the stats and I'll be happy to help you out.
Its always a good iead to scan for malware and making sure you are running the latest versions of Windows etc..
Thx
Craig
BTCare Community Mod
If we have asked you to email us with your details, please make sure you are logged in to the forum, otherwise you will not be able to see our ‘Contact Us’ link within our profiles.
We are sorry but we are unable to deal with service/account queries via the private message(PM) function so please don't PM your account info, we need to deal with this via our email account :-)”
td-p/30">Ratings star on the left-hand side of the post.
goral
Message 9 of 9
I have print copy of speed test from last week (3 prints in different time) and 3+ prints from this week.
And result is nearly identical.
8000 IP Profile is from about 20 days, and speed first was very unstable, jumping from 100kb/s to 7000kb/s (when I download two files in this same time from Microsoft website).
Before it was excellent, I have IP Profile 10000 and my speed was nearly my IP Profile.
When I reset My BT Hub 20 day ago (it was not working - something like hanging) starting my problem with speed.
So may be just restart will help?
