tdwalker
Message 1 of 16
IP Profile Set Very Low
For the past two months my internet speed has been crippled because the IP profile has been set to a fraction of what it should be. Even though my line is capable of much higher speeds, once again the speed we are getting is far less than what we are paying for.
1. Best Effort Test: -provides background information.
 Download  Speed
 0.23 Mbps
0 Mbps0.25 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.23 Mbps
 For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
 Additional Information:
 Your DSL Connection Rate :1.82 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.25 Mbps
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 01:35:55
Downstream:1.781 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):18.5 dB / 19.0 dB
Line attenuation (Down/Up):54.7 dB / 31.5 dB
Output power (Down/Up):18.6 dBm / 11.9 dBm
FEC Events (Down/Up):124 / 3
CRC Events (Down/Up):13 / 5
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):15 / 0
Error Seconds (Local/Remote):1707 / 125
I've done the quiet line test, and there wasn't any noise or clicking sounds.
I am not currently connected to the master socket, which is on a different floor to our study, but I did have the router connected there for a night to see if there would be any speed improvement.
As you can see, I've only been getting 12.6% of the speed we've been paying for over the last two months, with the exception of a few days last week. From Wednesday 12th to Saturday 15th the IP profile was set to the correct level and we were getting our proper internet speed, but since then it's gone back to being slow.
I have already called the BT customer service four times over the course of the last month, and that is the only improvement that has occurred. This is the third time this has happened since we joined BT just over a year ago, and it is ridiculous how often I've had to go through this exact same procedure to get this sorted out.
There's nothing wrong with our line, our socket or our router. The IP profile is too low. Please reset it, and ensure this doesn't happen again less than four months from now.
15 REPLIES 15
Message 2 of 16
Re: IP Profile Set Very Low
hi you need to maintain a stable connection for 5days and your IP Profile will rise automatically your profile has dropped because of a unstable connection unless you can maintain a stable connection your profile will drop again
your noise margin is also high which is reducing your connection speed this also show the same cause an unstable line you should have a connection speed of around 3.9mb
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 3 of 16
You must leave your home hub turned on and connected to your phone line for at least five days.
During that time, do not reset or disconnect it.
If your download speed has not increased after that time, then return to this thread for assistance.
If you do a speed test, then do not restart the home hub, even though it tels you to, as this will reduce your speed even more.
You have a margin of 18.5dB, so there is plenty of room for improvement if you leave things alone.
tdwalker
Message 4 of 16
My internet connection is now back to full speed. Thank you very much! This was much faster than using the BT call centre.
 Download  Speed
 1.38 Mbps
0 Mbps2 Mbps
 Download speedachieved during the test was - 1.38 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 IP Profile for your line is - 1.5 Mbps
Message 5 of 16
Excellent Smiley Happy
Most issues will fix themselves provided people leave things connected and do not restart things.
One of the major problems is the BT Speedtester page, which tells people to restart their home hub before doing a speed test.
This action is counter productive, and repeated speed tests, following thos instructions, will make your speed even slower.
Message 6 of 16
Hi pleased to see all is now back to normal if you ever need any help in the future please post back here and someone will be pleased to try and help you
tdwalker
Message 7 of 16
Unfortunately our IP profile has been reduced again. I'll post the speed test results and the broadband settings again.
Download  Speed
 0.37 Mbps
0 Mbps0.5 Mbps
 Download speedachieved during the test was - 0.37 Mbps
 For your connection, the acceptable range of speeds is 0.05 Mbps-0.5 Mbps.
 Your DSL Connection Rate :0.77 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.5 Mbps
Connection time:0 days, 05:16:55
Downstream:768 Kbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):24.6 dB / 18.0 dB
Line attenuation (Down/Up):54.8 dB / 31.5 dB
Output power (Down/Up):16.4 dBm / 11.9 dBm
FEC Events (Down/Up):43216 / 295
CRC Events (Down/Up):6128 / 178
HEC Events (Down/Up):13550 / 174
Error Seconds (Local/Remote):1517 / 305
Could you please reset my IP profile? I wish it could stay at full speed without me having to do this each time.
Message 8 of 16
as before you need to maintain 5 days stable connection it is not an IP Profile problem it is an increased noise margin caused by multiple disconnections of the hub
russellmiddleton
Message 9 of 16
I'm paying for BT Broadband Option 3 on Line **Edited**
Sun 20120722 22:47:50 BST ADSL Speed (DS/US) Sync 2432/736 Kbps
Sat 20130316 08:36:37 GMT ADSL Speed (DS/US) Sync 2272/896 Kbps
Micro filter replaced after a week of connection dropping.
Hard restart Voyager 2100 (twice to get hub back online)
Sat 20150620 09:21:01 BST ADSL Speed (DS/US) Sync 1152/800 Kbps Noise Margin 17.5/7.0 dB Speed 0.94/0.67 Mb/s
Sun 20150621 08:04:16 BST ADSL Speed (DS/US) Sync 1152/800 Kbps Noise Margin 17.5/7.0 dB
Mon 20150622 22:24:03 BST ADSL Speed (DS/US) Sync 1152/800 Kbps Noise Margin 13.5/7.0 dB
Wed 20150624 20:26:09 BST ADSL Speed (DS/US) Sync 576/864 Kbps Noise Margin 17.1/7.0 dB
start testing with btwholesale
Thu 20150625 21:55:54 BST ADSL Speed (DS/US) Sync 576/864 Kbps Noise Margin 25.1/7.0 dB Speed 0.48/0.69 Mbps
Fri 20150626 am       BST ADSL Speed (DS/US) Sync 576/928 Kbps Noise Margin 22.2/7.0 dB Speed 0.49/0.74 Mbps
Fri 20150626 19:19:28 BST ADSL Speed (DS/US) Sync 576/928 Kbps Noise Margin 23.1/7.0 dB Speed 0.48/0.67 Mbps
Sat 20150627 07:29:11 BST ADSL Speed (DS/US) Sync 576/928 Kbps Noise Margin 20.9/7.0 dB Speed 0.50/0.72 Mbps
Sun 20150628 08:16:18 BST ADSL Speed (DS/US) Sync 576/832 Kbps Noise Margin 20.9/7.0 dB Speed 0.49/0.13 Mbps
Mon 20150629 06:28:06 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 15.9/10.0 dB Speed 0.49/0.61 Mbps
Tue 20150630 06:27:18 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 15.9/10.0 dB Speed 0.50/0.62 Mbps
Wed 20150701 06:20:52 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 19.0/10.0 dB Speed 0.50/0.63 Mbps
Thu 20150702 06:36:06 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 22.1/10.0 dB Speed 0.49/0.62 Mbps
Fri 20150703 06:39:38 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 17.1/10.0 dB Speed 0.50/0.62 Mbps
Sat 20150704 09:15:45 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 17.4/9.0 dB Speed 0.49/0.59 Mbps
Sat 20150704 10:07:27 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.4/9.0 dB Speed 0.48/0.62 Mbps
Sun 20150705 07:43:47 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.4/9.0 dB Speed 0.49/0.62 Mbps
Mon 20150706 06:45:26 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.7/9.0 dB Speed 0.49/0.55 Mbps
Mon 20150706 20:23:12 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.9/9.0 dB Speed 0.50/0.62 Mbps
Tue 20150707 06:51:20 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 25.9/9.0 dB Speed 0.49/0.62 Mbps
Tue 20150707 18:56:16 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.9/9.0 dB Speed 0.51/0.63 Mbps
Wed 20150708 07:02:02 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.9/9.0 dB Speed 0.50/0.62 Mbps
Wed 20150708 21:25:57 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.6/9.0 dB an error occurred on BTWholesale
Thu 20150709 06:54:16 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.6/9.0 dB Speed 0.44/0.57 Mbps
Thu 20150709 18:35:52 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.6/9.0 dB Speed 0.49/0.55 Mbps
Fri 20150710 06:53:55 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.8/9.0 dB Speed 0.49/0.62 Mbps
Fri 20150710 20:46:27 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.7/9.0 dB Speed 0.42/0.62 Mbps
Sat 20150711 08:34:22 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.8/9.0 dB Speed 0.50/0.63 Mbps
Sat 20150711 17:24:41 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 24.8/9.0 dB Speed 0.50/0.63 Mbps
Soft restarted Voyager 2100
Sat 20150711 17:33:31 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 25.1/10.0 dB Speed 0.49/0.62 Mbps
Sun 20150712 07:03:48 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 25.3/10.0 dB Speed 0.49/0.57 Mbps
Mon 20150713 06:22:21 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 25.4/10.0 dB Speed 0.49/0.62 Mbps
Mon 20150713 19:13:05 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 25.4/10.0 dB Speed 0.50/0.55 Mbps
Tue 20150714 06:22:06 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 25.4/10.0 dB Speed 0.49/0.55 Mbps
Tue 20150714 18:54:09 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 25.4/10.0 dB Speed 0.42/0.56 Mbps
Wed 20150715 06:37:31 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 25.3/10.0 dB Speed 0.43/0.56 Mbps
Wed 20150715 18:48:59 BST ADSL Speed (DS/US) Sync 576/768 Kbps Noise Margin 25.3/10.0 dB Speed 0.49/0.62 Mbps
Profile used to be 2000 now it's stuck at 500. Connection holds for 24/7 There appears to be more than enough Margin to try a higher sync. OK so maybe I was a bit slow replacing the micro filter. But we're approaching 4 weeks of, what looks to me like, a very stable connection. So much for the "speed should improve after 5 days of stability."
Message 10 of 16
From looking at the stats which I found difficult to follow but it looks like due to your previous disconnection problems you are currently in banded profile and it takes 3/5 days stable connection for banding to start to release. http://www.plus.net/support/broadband/speed_guide/broadband_terminology.shtml
