jimbob
Message 1 of 4
IP Profile changing randomly
One of the problems I face after ringing bt for help about 2 weeks about being a new customer (3 weeks) and having latency probems any gamer would be unhappy with.
Download speedachieved during the test was - 10740 Kbps
 For your connection, the acceptable range of speedsis 100-500 Kbps.
 Additional Information:
 Your DSL Connection Rate :21595 Kbps(DOWN-STREAM), 1163 Kbps(UP-STREAM)
 IP Profile for your line is - 548 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 11.69:17.75:70.57 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Quad Core 3.42ghz @ idle/load 29/37C (water cooler)
Northbridge 2.2ghz / HyperLink 2ghz
4gb ram gt 1.600mhz
4870x1 2gb vram vapper
wireless (free)
3 REPLIES 3
Badlandz
Message 2 of 4
Re: IP Profile changing randomly
What speed are you paying for?
express
Message 3 of 4
Unfortunately you do not pay for speed only bandwith it's highly likely that is a failed test as the throughput clearly couldn't have been 10740kbps on the 548kbps profile or vice versa give it a few hrs and then check again.
jimbob
Message 4 of 4
I only checked this after seeing my connection consistenly drop down to 1mb.
This was never like this in my trial time and so I did not have to wait all the time for web pages to load.
Im being riped off. and at what point did you think id pay for this? lol 6 years isnt it?
4gb ram gt 1.600mhz
wireless (free)
