Message 1 of 13
IP Profile reset after Openreach visit.
I have been having some line problems over the last 2 months that may now be fully resolved but I don't seem to be able to reach the heady heights of a 1Meg broadband profile. It seems the line sticks firmly to .75Meg even when I have sync at 1120 and historically I can achieve 1Meg with occasional set backs to .75Meg. I evidence of being continuously connected from 15th - 18th July and currently too have a downloand synch of 1120Kbps but nothing seems to move me up from .75 to 1Meg. My line attenuation is 63.5 so I am making best efforts to squeeze out a usable broadband service. I will reference the post to see if the Mods can organise an IP profile check/reset.
12 REPLIES 12
Message 2 of 13
Re: IP Profile reset after Openreach visit.
Hi can you please post your full hub stats and the full BT speedtest showing yor ip profile if you can show hubstats with 3+ days stableconnection we can give you a link to contact the forum mods but the stats and full speedtest results must be posted first please
Message 3 of 13
Also your ip profile is controlled by your connection speed not the other way round from your post your ip profile looks to be in the correct area but the hub stats and full BT speed test will help us confirm this tthen if needed the mods can be contacted
This is the address for the speed test speedtester.bt.com. The full test please not the beta version
Message 4 of 13
Message 5 of 13
ADSL line status
Connection information
Line stateConnected
Connection time1 day, 0:17:10
Downstream1,120 Kbps
Upstream384 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)6.4 dB / 8.0 dB
Line attenuation (Down/Up)63.5 dB / 31.5 dB
Output power (Down/Up)15.8 dBm / 12.4 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)17341358 / 338
CRC Errors (Down/Up)8199 / 2147480000
HEC Errors (Down/Up)nil / 204
Error Seconds (Local)6
Message 6 of 13
18/07/12 18:31 Wed620 Kbps323 Kbps86.141.156.37BT ADSL
18/07/12 09:13 Wed689 Kbps323 Kbps86.141.156.37BT ADSL
17/07/12 10:36 Tue646 Kbps306 Kbps86.141.156.37BT ADSL
17/07/12 09:41 Tue636 Kbps302 Kbps86.141.156.37BT ADSL
16/07/12 18:26 Mon688 Kbps323 Kbps86.141.156.37BT ADSL
16/07/12 15:34 Mon663 Kbps316 Kbps86.141.156.37BT ADSL
15/07/12 23:44 Sun709 Kbps322 Kbps86.141.156.37BT ADSL
Message 7 of 13
hi your IP profile is correct for your connection speed there is nothing to reset the only way to get an increase of profile is if your connection speed increases
Message 8 of 13
your profile is correct for your connection speed and to get a 1mb profile you need a connection speed of at least 1152.
you are on a long line as router showing 63.5 which is as high as most show so your true attenuation may well be a lot higher.
are you connected to the master or test socket?  do you have other extension sockets in other rooms?
Message 9 of 13
Thanks for both replies.
I am grateful for the information that I need a connection of 1152 or higher for a chance to improve to a 1meg speed.
I am using the master socket with the special built in ADSL filter that excludes extensions.
Message 10 of 13
not a lot more you can do apart from consider a bt businees router 2700hgv which has a good reputation of improving/holding connection on longer lines.  they can be obtained from well known auction site not expensive but need to make sure new and sealed.
search the forum for business router 2700hgv and you will see others comments
