Message 1 of 12
IP Profile stuck at 2000kbps - used to be higher!
Hi
Back in July I lost my broadband connection for 5 days. After 3 phone calls to the help desk I was told an engineer would be sent although I was pretty sure that the problem was not in my house. The night before the engineer was to visit, the red light on my HomeHub 2 changed from red to blue and I was back in business. The engineer arrived the following morning and checked everything and could find no problem.
My problem is now is that my IP profile is stuck at 2000 Kbps.
I have done everything I can to try and improve the speed:
1 – Connect directly to main phone socket.
                Not tried as everything worked before and the extension is a BT extension anyway.
2 – Changed all my Micro filters
3 – Installed a Broadband Accelerator
Here are the BT Speed test results – Can anyone advise if there is something wrong with the figures below?
Download speed achieved during the test was - 1813 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
Data from my router.
ADSL line status
Connection Information
Line stateConnected
Connection time         10 days, 08:41:14
Downstream                   8,128 Kbps
Upstream  448 Kbps
ADSL Settings
VPI/VCI       0/38
Type             PPPoA
Modulation                     G.992.1 Annex A
Latency type                  Interleaved
Noise margin (Down/Up)               12.4 dB / 30.0 dB
Line attenuation (Down/Up)          24.0 dB / 11.5 dB
Output power (Down/Up)             13.8 dBm / 2.0 dBm
Loss of Framing (Local/Remote)    0 / 0
Loss of Signal (Local/Remote)       0 / 0
Loss of Power (Local/Remote)      0 / 0
FEC Errors (Down/Up)                  2113 / 1
CRC Errors (Down/Up)                 4 / 0
HEC Errors (Down/Up)                  5 / 0
Error Seconds (Local/Remote)     4 / 0
Here are some stats from ThinkBroadband showing I used be in the 6000kbps range before July.
Date                             Day               Downstream                Upstream
08/10/11 15:03           Sat                 1880 Kbps                   374 Kbps
23/09/11 07:06           Fri                  1897 Kbps                   374 Kbps
22/09/11 23:06           Thu               1625 Kbps                    367 Kbps
11/08/11 21:27           Thu               513 Kbps                      364 Kbps
31/07/11 22:51           Sun               1887 Kbps                    371 Kbps
10/02/11 19:44           Thu               5707 Kbps                    374 Kbps
17/02/10 22:31           Wed             2309 Kbps                     376 Kbps
23/01/10 08:53           Sat                 6207 Kbps                   374 Kbps
24/12/09 14:43           Thu               2645 Kbps                    374 Kbps
23/12/09 07:36           Wed             6123 Kbps                     374 Kbps
19/08/08 00:30           Tue               6592 Kbps                    376 Kbps
18/04/08 21:47           Fri                  3281 Kbps                   376 Kbps
25/03/08 20:26           Tue               2345 Kbps                    377 Kbps
17/11/07 01:09           Sat                 6085 Kbps                   376 Kbps
15/11/07 07:40           Thu               5999 Kbps                    370 Kbps
08/11/07 00:04           Thu               6084 Kbps                    376 Kbps
05/11/07 07:11           Mon             6081 Kbps                     375 Kbps
04/11/07 14:42           Sun               2925 Kbps                    376 Kbps
02/10/07 23:42           Tue               4333 Kbps                    376 Kbps
03/09/07 00:21           Mon             6075 Kbps                     376 Kbps
31/07/07 07:26           Tue               6562 Kbps                    376 Kbps
24/05/07 08:34           Thu               6536 Kbps                    376 Kbps
29/03/07 23:32           Thu               6401 Kbps                    376 Kbps
18/02/07 16:41           Sun               5094 Kbps                    376 Kbps
13/01/07 19:08           Sat                 5971 Kbps                   376 Kbps
31/12/06 01:23           Sun               6400 Kbps                    376 Kbps
03/12/06 01:31           Sun               5992 Kbps                    376 Kbps
11 REPLIES 11
Message 2 of 12
Re: IP Profile stuck at 2000kbps - used to be higher!
Hi I suggest you contact the forum mods and ask them to reset your ip profile for you this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 72 hours
They are a UK based specialist team who have a good record at getting problems solved
Message 3 of 12
BT found that my IP rating was showing correctly in one system but only as 2000kbps in another.  I am now getting 6379 download speed which I am happy with.
Message 4 of 12
Hi glad you have the problem solved if you need any help in the future then please post back
Message 5 of 12
Hi
June 2012 and the IP profile has reverted back to 2 Mbps - for the last 8 months I was getting between 6 & 8 Mbps download speeds after the configuration error was corrected.  Please can you check the setup once more?
Speed test from Friday 22/6/2012 at about 21:25
 Download speedachieved during the test was - 1.73 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
Many thanks
Paul Ellmer
Message 6 of 12
you need to post the stats from your router please
Message 7 of 12
hi can you post your current hub stats if you have a 3days + connection then you need to contact the forum mods for an IP profile reset
Message 8 of 12
Here is my HomeHub stats and below is a BT Speedtest.  I reset the hub before I went away on business on Wednesday so it has not really been used in the last three days.
ADSL line status
Line state Connected
Connection time 2 days, 10:45:41
Upstream 448 Kbps
ADSL Settings
VPI/VCI 0/38
Type PPPoA
Latency type Fast
Noise margin (Down/Up) 10.7 dB / 30.0 dB
Output power (Down/Up) 12.4 dBm / 2.0 dBm
FEC Errors (Down/Up) 0 / 9
CRC Errors (Down/Up) 2861 / 47
HEC Errors (Down/Up) 3239 / 8
Error Seconds (Local/Remote) 2658 / 10
BT Speedtest
Message 9 of 12
post new stats tomorrow to show the 3+ days connected and then contact mods
contact mods
can take up to 3 working days for mods to contact you
Message 10 of 12
ok once you have 3days + connection contact the mods and ask for a reset
