Message 1 of 4
IP Profile
Can someone please reset my IP profile?
Data rate:
447 bps / 4.54 kbps
Maximum data rate:
1208 / 9128
Noise margin:
27.7 / 15.9
Line attenuation:
44.5
Signal attenuation:
254 / 445
Download speedachieved during the test was - 3.9 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
 IP Profile for your line is - 4.01 Mbps
Upload speed achieved during the test was - 0.31Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.45 Mbps
3 REPLIES 3
Message 2 of 4
Re: IP Profile
your IP profile is correct for your connection speed
Message 3 of 4
Re: IP Profile
The line seems banded, given the large difference between connection and attainable rate.
How long has your current connection been active? Have you experienced an unstable line recently?
Message 4 of 4
Re: IP Profile
Ive had the connection since march 3rd last year which is a second line into my property and for the first month sync'ed at 8mbps. The first line doesnt have this problem and is sync'ed at around 8-9mbps down and 1.-1.3mbps up constantly and my line's been stable for a while so i don't understand why it's so low.
