Message 1 of 6
IP Prrofile stuck for 4 days
Not had speeds of more than 2mb for a month now. Last 4 days it has been 0.6mb. Profile seems to be stuck at 0.7.
5 REPLIES 5
Message 2 of 6
Re: IP Prrofile stuck for 4 days
can you post your adsl stats from your router please  normally need 3/5 days connection time for profile to change
Message 3 of 6
Message 4 of 6
Thats ALOT of Information on they ADSL Settings.
IP Addresses etc, Serial Numbers, should blank some of that out -.-
Message 5 of 6
your connection speed shown in the btspeedtester results id different from the connection speed shwon by your router suggesting that there has been a disconnection.  with the high noise margin of 16 it also suggests that there is a noise problem which probably results in resets by the hub.
even though your router has been connected everything suggests that you have not managed the 24/7 connection for 3/5 days required to get the profile to change automatically.
edited following gouledw post
Recognised Expert
Message 6 of 6
Profile you mean IMJ, 😉
