I have a BT smart hub type A. I can connect devices to it, but all devices say connected, no internet. My hub has a consistent blue light, so there is obviously internet.
This happens almost daily to one device or other. I phoned BT about it a couple of months ago. They reset the hub, it worked for a few days.
I now have to reset the hub almost daily, even then it doesn't always work. It hasn't worked today
I ran a troubleshoot on my laptop earlier and got "WiFi doesn't have a valid IP connection". I have tried to report a fault online, but it just comes back as speed is good (it probably is... If I could connect!).
Reading helpful posts on the community (thank you 😁) it looks like I need a new hub. I've repeatedly called the fault line, but it keeps disconnecting 😠 I have no wifi and I'm trying to work from home. I can't use all of my mobile data up!
Any help with alternative solutions? How can I arrange a new hub online?
if you have HH6 then try turning off smart setup. you can also split the 204/5ghz networks which often helps with wifi devices
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
to get a new replacement hub you need to phone 151 and report a faulty hub
