Grouchy
Message 1 of 62
IP profile now 87
I have got into the habit of running a BT speedtest at [http://www.speedtester.bt.com/] once a week or so - probably unnecessary I know but at least I think I might be forewarned of IP profile drops and such...
Anyway.. just run one this morning and was surprised to see my IP profile has gone up from 77.43 to 87.5
Download speed is also showing a slight increase.
I thought Infinity had a maximum of circa 80Mbps - in which case how come my profile is so much higher? Has there been some sort of covert upgrade done?
Not complaining mind you - just curious.....
61 REPLIES 61
Guru
Message 2 of 62
Re: IP profile now 87
Was a post last week that someone achieved over 80Mbps on their IP profile, maybe they're doing some more tests. Not to sure, hopefully someone can answer your question. 🙂
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Guru
Message 3 of 62
I'm not at all sure, curious as well. I noticed someone else posted an 83Mb profile a couple of days ago or so.
Ratty2012
Recognised Expert
Message 4 of 62
Just checked mine and it now reads: IP Profile for your line is - 87.5 Mbps
BuckleZ
Message 5 of 62
Still  IP Profile for your line is - 77.43 Mbps
On a reasonably short line here.
Ratty2012
Recognised Expert
Message 6 of 62
Maybe your profile will change over the next few days
BuckleZ
Message 7 of 62
Are you stil synced at around 80meg? This all doesn't make sense lol
Ratty2012
Recognised Expert
Message 8 of 62
I don't have access to my line stats, so I don't know what the sync rate is
Colin_London
Recognised Expert
Message 9 of 62
Since the beginning of September my profile has gone from a consistent 64Mbps to a consistent 69Mbps (Line length 370m to cab).
Maybe they have updated the firmware on the VDSL2 modems in the cabinets and they are performing better than before so they have added higher profiles?
Isn't the VDSL profile used (17a?) theoretically capable of up to 100Mbps?
martpu
Expert
Message 10 of 62
I was the bloke who posted that his IP Profile was 83.63 Mbps but I've still not found out why.
Shall keep an eye on this thred in the hope all will be revealed in time!
________________________________________________________________________
You won't get to ride the racehorse...until you've ridden the mule.... - RogerB 13/04/2010
