Message 11 of 20
Re: IPC6023 and IPC6011 error with New router Asus DSL-AC68U
Would that be the "DNS Server" field?
Message 12 of 20
Sounds about right ( sorry left the house so can't check exactly the naming of the field )
Message 13 of 20
I would try flipping the settings so that the DHCP DNS Server field is blank and popping the two server addresses under the WAN area I mentioned earlier.
I could spend some time comparing my settings with yours in detail if you wish sometime?
Message 14 of 20
Ill try swapping over the DNS later on when i get home and then reboot the router and youview and see if it works and if not we can go down the comparing settings road, thanks again for all your help so far.
Message 15 of 20
Not a problem. Just to check, I removed my DNS to use BT's last night and then tried Google's again early this morning and my IPTV is working fine with both.
Message 16 of 20
so i did the DNS changes and reboot both boxes and it seems to be working fine now. Thanks again for all ur help
Message 17 of 20
Pleasure - enjoy the kit and if you haven't already it is worth tinkering with the DSL settings. You can get a bit more stability and sync speeds if you know what you're doing 😉
Message 18 of 20
care to share your setting ScottSilver??
mine is performing pretty well, but is stuck on interleaved - not sure if that's my fault or a line issue?
Message 19 of 20
You might not get a reply, he hasn't posted on the forum for nearly 2 years.
Message 20 of 20
ah.............
I should have checked - sorry
