Message 1 of 10
IPC6023 error and no paid for channels for two weeks now!
Hi, I was wondering if anyone can help.
I have had bt tv for nearly two years no problem but on Sunday 12th I noticed that my internet channels would not work - I get a black screen and then Ipc6023 error message including channel 399.
An engineer has come out to the property and confirmed not an issue my end. This was escalated to level 2 and 3 with multiple promises to call back - unfortunately they keep ringing the landline which I have said on many occasions does not have a working phone and to call my mobile. As I am writing this I am still waiting for a call back 'within the hour'. Frustrating to say the least.
I am connected through power adapters but have also tried the box connected to the hub directly using an upstairs tv. Same issue. All advice has been followed i.e. Resetting, check wires etc but still no luck. My broadband is working perfectly and speed is fine (I work from home daily and no issues) and my youview box is connected to the internet - I can access iplayer etc.
Any help would be greatly appreciated.
9 REPLIES 9
Message 2 of 10
Re: IPC6023 error and no paid for channels for two weeks now!
@Jgratton2
I will move this post to the YouView board.
Have you tried the vision live chat team
Message 3 of 10
Yes. THey just keep telling me to go through resetting etc asking the same questions over and over again. Wanting to send out another engineer to check I have my wires plugged in properly. Not really getting anywhere with them.
Have phoned back multiple times but get the same too.
Message 4 of 10
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Message 5 of 10
@Keith_Beddoe
Thank you
Distinguished Guru
Message 6 of 10
Hi @Jgratton2,
Welcome to the Community Forums.
There are a few different scenarios that can cause this issue. It needs to be investigated thoroughly. You can get in touch with us by clicking on my user name and then on contact the mods. This will raise a ticket for us to investigate. It can take 1-3 working days before we can reply back.
DanielS
Message 7 of 10
Hi @DanielS
Has there been any progress made on my case - reference number is 161224-******.
On the 28th I was advised of super stability mode being put on the line but this has not made any difference.
Message 8 of 10
Problem is back again 😞 reset, checked wires, plugged directly in to broadband hub etc.
Moderator
Moderator
Message 9 of 10
Hi @Jgratton2 Sorry that the fault has come back. I can see that you have sent in your details again today and we will get this resolved for you as soon as we can.
John
Message 10 of 10
@JohnC2 thank you for your help.
