I'm on BT Infinity and I have just got myself an Asus DSL-AC88U router. I was going through the settings and have enabled IPv6, setting it to 'Native'. The other options I had available to me were Disable, Tunnel 6to4, Tunnel 6in4, Tunnel 6rd and Static IPv6.
Any tips on what this all means and if I should just leave it alone? Everything seems normal with it set to Native...
Native is correct setting
Everything will continue to work fine with IPv6 enabled. Most devices will try to connect with Ipv6 first if possible. Native setting is fine.
Thank you for the feedback!
