I posted a month or so ago on one of the threads that I wasn't getting an IPv6 address despite settings on my ASUS router being correct. That sorted itself a couple of weeks ago, after a scheduled reboot I realised I was now getting those provided.
The problem is that although I'm seeing addresses in the router and on this Win 10 desktop I'm getting total IPv6 failure when testing with ipv6-test.com (4 out of 20) and test-ipv6.com (4 out of 10).
From my Router:
IPv6 Connection Type Native with DHCP-PD WAN IPv6 Address 2a00:23c5:7603:eb00::1 WAN IPv6 Gateway fe80::ea4:2ff:fe3e:1 LAN IPv6 Address 2a00:23c5:7603:eb00::1/56 LAN IPv6 Link-Local Address fe80::a60:6eff:fecc:1ff0/64 DHCP-PD Enabled LAN IPv6 Prefix 2a00:23c5:7603:eb00::/56 DNS Address
From my PC:
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller Physical Address. . . . . . . . . : 50-46-5D-53-0A-4B DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : 2a00:23c5:7603:eb00:74c7:b68b:d752:ebd4(Preferred) Temporary IPv6 Address. . . . . . : 2a00:23c5:7603:eb00:c175:e222:ab04:682f(Preferred) Link-local IPv6 Address . . . . . : fe80::74c7:b68b:d752:ebd4%4(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.150(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : 08 May 2017 07:53:45 Lease Expires . . . . . . . . . . : 10 May 2017 17:58:21 Default Gateway . . . . . . . . . : fe80::a60:6eff:fecc:1ff0%4 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DHCPv6 IAID . . . . . . . . . . . : 256919133 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-96-69-B4-50-46-5D-53-0A-4B DNS Servers . . . . . . . . . . . : 2a00:23c5:7603:eb00::1 192.168.1.1 NetBIOS over Tcpip. . . . . . . . : Enabled
I'm not that familiar with IPv6 and I'm a little lost as to why it's not working. I've tried manually defining the IPv6 DNS servers (using Googles) but that didn't help.
Any one got an ideas? Or is this just another phase in BT enabling IPv6 on my connection - they've given me an address but don't want to route any traffic?
Solved! Go to Solution.
On the IPv6 test sites which tests are failing? On the http://test-ipv6.com/ site can you select the 'Tests Run' tab and then copy and paste the test results in the section below the 'Click to see Technical Info', for example:
Test with IPv4 DNS record ok (0.061s) using ipv4 Test with IPv6 DNS record ok (0.079s) using ipv6 Test with Dual Stack DNS record ok (0.080s) using ipv6 Test for Dual Stack DNS and large packet ok (0.080s) using ipv6 Test IPv4 without DNS ok (0.092s) using ipv4 Test IPv6 without DNS ok (0.089s) using ipv6 Test IPv6 large packet ok (0.090s) using ipv6 Test if your ISP's DNS server uses IPv6 ok (0.090s) using ipv6 Find IPv4 Service Provider ok (0.136s) using ipv4 ASN 2856 Find IPv6 Service Provider ok (0.080s) using ipv6 ASN 2856
From the PC what happens if you run ping -6 google.com from the command prompt? And any luck with ping -6 2a00:1450:4009:807::200e?
I see from the ipconfig output that you have the Asus set as an IPv6 DNS server. Have you also configured an IPv6 DNS server to forward the received DNS requests to?
Regards
Seems strange seeing as you are getting the prefix and the router is passing addresses through.
Have you set the DNS servers in the router?
Shouldn't stop things working though, if you haven't.
Use openDNS servers here, set in the router and all PC's.
IPv4
208.67.220.220
208.67.222.222
IPv6
2620:0:ccc::2
2620:0:ccd::2
Hi smf22
Here's the results from test-ipv6
Test with IPv4 DNS record ok (0.270s) using ipv4 Test with IPv6 DNS record timeout (15.008s) Test with Dual Stack DNS record ok (0.094s) using ipv4 Test for Dual Stack DNS and large packetok (0.054s) using ipv4 Test IPv4 without DNS ok (0.065s) using ipv4 Test IPv6 without DNS timeout (15.003s) Test IPv6 large packet timeout (15.010s) Test if your ISP's DNS server uses IPv6 ok (0.111s) using ipv4 Find IPv4 Service Provider ok (0.239s) using ipv4 ASN 2856 Find IPv6 Service Provider timeout (15.012s)
For the ping tests, the first one by name correctly resolved the IPv6 address but the ping timed out. The second one specifying the address itself also timed out.
For DNS Server - it's lef blank by BT as per my info grab from the router, but as said I've tried specifing Googles DNS servers and it made no difference but will try again.
I currently have the Google DNS servers set for IPv4 (8:8:8:8 and 8:8:4:4) and blank for Ipv6 as per what's provided by DHCP. I've tried specifying Googles IPv6 servers as I said but will try openDNS now and report back once the screaming from the teenagers dies down when they get disconnected.
UPDATE: Changed to the openDNS servers for v4 and v6 and retested test-ipv6.com and the pings and there is no change.
I thought I would try a trace route in both IP versions to google.com
IPv4
Tracing route to google.com [216.58.206.46] over a maximum of 30 hops: 1 2 ms 1 ms 2 ms RT-N66U-1FF0 [192.168.1.1] 2 * * * Request timed out. 3 * * * Request timed out. 4 8 ms 7 ms 8 ms 31.55.185.180 5 8 ms 7 ms 8 ms core2-hu0-8-0-5.colindale.ukcore.bt.net [195.99.127.154] 6 8 ms 8 ms 8 ms 195.99.127.85 7 10 ms 8 ms 8 ms 109.159.253.67 8 9 ms 11 ms 9 ms 108.170.246.193 9 9 ms 8 ms 9 ms 216.239.41.183 10 9 ms 9 ms 9 ms lhr35s10-in-f14.1e100.net [216.58.206.46] Trace complete.
and IPv6
Tracing route to google.com [2a00:1450:4009:812::200e] over a maximum of 30 hops: 1 3 ms 2 ms 7 ms broadband.bt.com [2a00:23c5:7604:3300::1] 2 * * * Request timed out. 3 * * * Request timed out. 4 * * * Request timed out. 5 * * * Request timed out. 6 * * * Request timed out. 7 * * * Request timed out. 8 * * * Request timed out. 9 * * * Request timed out. 10 * * * Request timed out. 11 * * * Request timed out. 12 * * * Request timed out. 13 * * * Request timed out. 14 * * * Request timed out. 15 * * * Request timed out. 16 ^C
Well, you can see where I got bored and escaped out.
So it looks like my requests get as far as the first BT box and then get discarded. Feeling a little offended
what benefit is there from using IPV6 sites?
My results are:
ok (0.097s) using ipv4
ok (2.075s) using ipv6
ok (0.125s) using ipv6
ok (2.932s) using ipv6
ok (0.087s) using ipv4
ok (1.990s) using ipv6
ok (2.993s) using ipv6
bad (0.073s)
ok (0.334s) using ipv4 ASN 2856
ok (1.186s) using ipv6 ASN 2856
If I disable DHCP-PD then I can specify the prefix. I'll give that a go tomorrow and let you know.
