prinknash
Expert
Message 91 of 96
Re: IPv6 addresses given but no connection
@paulferrari wrote:
The result of a 28 minute telephone conversation with BT is that IPv6 is not available over their whole network automatically. I am on part of their IPv4 network that is being deprecated so giving me IPv6 involves moving me to a new IPv4 address which will also be enabled for IPv6.
Seems odd, given that BT's Chief Network Architect announced in November 2016 that roll-out of IPv6 had been completed "for all BT broadband lines" for people who had compatible routers.
p
paulferrari
Message 92 of 96
Sorry I should have added that the router is on a static IP address that has been in use for 10+ years.
By 'compatible routers' I assume that BT mean their own and not any of the others out there.
licquorice
Message 93 of 96
Ah, in which case I (a) presume this is a business line and (b) you will have to request a static IPv6 address as well rather than being allocated a dynamic IPv6 address.
paulferrari
Message 94 of 96
Yes the line is a business line with a static IPv4 address.
Beware of Cerys Ramsden at BT. She changed our account over to a dynamic IP which obviously cut off access to all the services including a mail server on the previously static IP address. this did not result in an IPv6 connection either.
I have spent all morning on the phone to BT business ending up with a manager called Faye who actually knoew what she was talking about. She ordered back our original IPv4 static address with IPv6 functionality which will take place on Monday. In the meantime we have a pemporary statc IPv4 address with an IPv6 connection as well.
This confirms that the settings above for Draytek routers is correct and works with BT infinity, altoght it might be necessary to ask BT to enable IPv6 functionality on your account if you cannot make a connection.
It also confirms that the people above were correct to be skeptical about Cerys Ramsden's action of converting the account to dynamic in order to enable IPv6. That was clearly misconceived. i have suggested that she be retrained.
Keith_Beddoe
Message 95 of 96
@paulferrariYou would be better posting on the BT Business forum at http://business.forums.bt.com/
as this is the residential forum.
licquorice
Message 96 of 96
This is the residential forum, you would have been better served posting on the business forum https://business.forums.bt.com/
