Message 71 of 96
Re: IPv6 addresses given but no connection
Sounds promising!  Can test first thing tomorrow.
Can you confirm what was changed?
Message 72 of 96
Wow what a hell of a difference that has made ! Everything is now flying with BT Whole Home WiFi and Superhub ..
Cheers guys !
Message 73 of 96
You sir are a star 🙂
ping -6 ipv6.l.google.com
Pinging ipv6.l.google.com [2a00:1450:401b:803::200e] with 32 bytes of data:
Reply from 2a00:1450:401b:803::200e: time=33ms
Ping statistics for 2a00:1450:401b:803::200e:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 33ms, Maximum = 33ms, Average = 33ms
And thank you @smf22 for your help 🙂
Message 74 of 96
Yes, just to confirm I'm up and running too.  Pings are working, test-ipv6.com gives me a 9 out of 10, with only the known 'gap' around BT's DNS (which isn't a real problem at the moment).
Thanks for the fix!
Moderator
Moderator
Message 75 of 96
Hi All. Thanks for checking that and posting back to confirm it has been fixed. I'm sorry but I can't tell you what the exact problem was.
Cheers
John
Expert
Message 76 of 96
As a matter of interest, what is that 'gap' about.
What problem could that cause?
Please keep it simpleSmiley Embarassed
Recognised Expert
Message 77 of 96
The gap is that currently the BT DNS servers only have IPv4 address i.e., 81.139.56.100 and 81.139.57.100. A full implementation would have the DNS servers themselves with an IPv4 and IPv6 address so clients could send queries to them on either IPv4 or IPv6.
This is not an issue as an IPv4 DNS server will, when asked, return the IPv4 and IPv6 of the site you're trying to connect to. For example, the following is a lookup of www.facebook.com to one of the BT DNS servers on its IPv4 address, but as you can see the response is both the IPv4 and IPv6 address.
C:\Users\smf22>nslookup www.facebook.com 81.139.56.100
Server:  UnKnown
Address:  81.139.56.100
Non-authoritative answer:
Addresses:  2a03:2880:f11a:83:face:b00c:0:25de
          157.240.1.35
Aliases:  www.facebook.com
Message 78 of 96
Can you tell me what the correct setting are to enable IPv6 on a draytek vigor2860 please?
Expert
Message 79 of 96
Welcome to the forum.
I don't use one of those routers but you could have a look in the IPv6 configuration page(s) for something along these lines.
Native connection
DHCP_PD Enable
Auto Configuration Setting Stateless
Connect to DNS Server automatically Enable
Enable Router Advertisement Enable
What does the manual tell you to do?
Message 80 of 96
Thank you for the reply. The manual says that the settings depend on what ISP requires, hence my question to BT.
The first choices on the IPv6 connection page relate to the connection type:
PPP
TSPC
AICCU
DHCPv6 client
static IPv6
6in4 Static Tunnel
6rd
These are all available as a first step.
